kd _ 工业工程网
精益生产 11839 30 2010-10-2 13:18:13
Before designed, KD has already considered adequately the practical needs of the customers, so the finished products appeared more functionality and economical efficiency.
***kd partition wall Excellent structure combination of inner steel and outer aluminium unifies the inside consistency with outside aesthetics perfectly of the partitions for commercial use.
***KDpartition panelSlim assembly profiles between modules maximumly bring about the brightness and integrity of the glazed partitions. Covering profiles made of metal increase greatly the stability and flatness of glass panel with large size.
***KD partition wall Finished international patent design of L, T, and Y connections turns the difficulties into highlights of the partition products.
***KD partition wall Perfect sound insulation system of KD partitions completely blocks every channel that transfers sound, which leads to an unusual sound insulation of the partitions.
***KD partitions make every effort to avoid complicated structures in design and enable customers to get perfect product with least cost.
***KD partitions has obtained ETA standard test of impact resistance, which provides guarantee of safe use of the customers.
Doorframes of KD partitions are reinforced by the combination of inside steel support, solid door materials inside and aluminium doorframes outside.
The whole set of partition avoids to be fixed by rivets, which brings about the demountable function.
*** KD partitions involvedfixed partition wall and movable partition wall.<script src="http://www.6sq.com/batch.panel.php?rand=242780" type="text/javascript" language="javascript">最新发表
  • victor2008【加分讨论】PMC中物控部门的职责有
  • 小皮球拜师学艺(续2)
  • gansional求可靠性方面的标准!(急,有加分啊)
  • andywang0802一个关于抽样的问题
  • daishuang呵呵
  • booker塑胶部品如何防止缺胶不良发生
  • angel_1979请教关于偏离许可、让步接收、特采定义
  • xlin789SA8000急救箱需标准配制那些药品?
  • kanhanLED 支架  检查要点
关于我们 | 站点地图 | 友情链接 | 版权声明 |广告合作 |6SQ工具条 |联系我们
                        <script type="text/javascript" src="http://www.google.com/coop/cse/brand?form=cse-search-box&lang=zh-Hans">
联系电话:020-86292072 QQ:5877530
2021-1-29 09:33:04
2021-1-29 10:13:12
2021-1-29 10:18:42
2021-1-29 10:25:21
2021-1-29 10:26:06
2021-1-29 10:33:03
2021-1-29 10:34:11
2021-1-29 10:43:30
2021-1-29 10:57:19
