OEE计算 英文版 _ 工业工程网
精益生产 2091 30 2010-10-2 21:07:22
最基本的,希望对大家有用 和老外解释就不用那么麻烦了。。。
Calculating OEE
The Formulas
As described in World Class OEE, the OEE calculation is based on the three OEE Factors: Availability, Performance, and Quality. Here's how each of these factors is calculated.
Availability
Availability takes into account Down Time Loss, and is calculated as:
Availability = Operating Time / Planned Production Time
Performance
Performance takes into account Speed Loss, and is calculated as:
Performance = Ideal Cycle Time / (Operating Time / Total Pieces)
Ideal Cycle Time is the minimum cycle time that your process can be expected to achieve in optimal circumstances. It is sometimes called Design Cycle Time, Theoretical Cycle Time or Nameplate Capacity.
Since Run Rate is the reciprocal of Cycle Time, Performance can also be calculated as:
Performance = (Total Pieces / Operating Time) / Ideal Run Rate
Performance is capped at 100%, to ensure that if an error is made in specifying the Ideal Cycle Time or Ideal Run Rate the effect on OEE will be limited.
Quality
Quality takes into account Quality Loss, and is calculated as:
Quality = Good Pieces / Total Pieces
OEE
OEE takes into account all three OEE Factors, and is calculated as:
OEE = Availability x Performance x Quality
It is very important to recognize that improving OEE is not the only objective. Take a look at the following data for two production shifts.
OEE Factor        Shift 1        Shift 2
Availability        90.0%        95.0%
Performance        95.0%        95.0%
Quality        99.5%        96.0%
OEE        85.1%        86.6%
Superficially, it may appear that the second shift is performing better than the first, since its OEE is higher. Very few companies, however, would want to trade a 5.0% increase in Availability for a 3.5% decline in Quality!
The beauty of OEE is not that it gives you one magic number; it's that it gives you three numbers, which are all useful individually as your situation changes from day to day. And it helps you visualize performance in ** terms - a very practical simplification.
Example OEE Calculation
The table below contains hypothetical shift data, to be used for a complete OEE calculation, starting with the calculation of the OEE Factors of Availability, Performance, and Quality. Note that the same units of measurement (in this case minutes and pieces) are consistently used throughout the calculations.
Item        Data
Shift Length        8 hours = 480 min.
Short Breaks        2 @ 15 min. = 30 min.
Meal Break        1 @ 30 min. = 30 min.
Down Time        47 minutes
Ideal Run Rate        60 pieces per minute
Total Pieces        19,271 pieces
Reject Pieces        423 pieces
= [Shift Length - Breaks]
= [480 - 60]
= 420 minutes
Operating Time
= [Planned Production Time - Down Time]
= [420 - 47]
= 373 minutes
Good Pieces
= [Total Pieces - Reject Pieces]
= [19,271 - 423]
= 18,848 pieces
        =        373 minutes / 420 minutes
        =        0.8881 (88.81%)
        =        (19,271 pieces / 373 minutes) / 60 pieces per minute
        =        0.8611 (86.11%)
        =        18,848 / 19,271 pieces
        =        0.9780 (97.80%)
        =        0.8881 x 0.8611 x 0.9780
        =        0.7479 (74.79%)
futurepower (2008-11-17 12:39:22)好资料, 感谢! 方便了兄弟门呀 !!! 以后跟老外讲解这个真的是没有那么麻烦了aaron8 (2008-12-01 16:04:59)多谢啊楼主,对学习怎么用英文说很有用。rexxing (2008-12-04 20:34:41)不错,顶一下。。。。。。。。。。。。。。。
2011-2-22 03:19:22
多谢啊楼主,对学习怎么用英文说很有用
增加了见识啊
2021-1-9 16:23:35
2021-1-9 16:30:54
2021-1-9 16:55:20
2021-1-9 16:58:46
