UL黄卡识别方法的几个疑问 _ 工业工程网
质量管理 2977 30 2010-10-3 02:55:54
</script>附件中ELEC是什么意思?
      MECH中的IMP和STR是知的哪方面的机械特性?
回复的都加分!感谢ing``````
alliedsmt (2007-10-16 15:32:29)一般只有塑胶的黄卡才有这个信息.
Thermal Endurance
The temperature below which a class of critical property will not be unacceptably compromised through chemical thermal degradation, over the reasonable life of an electrical product (relative to a reference material having a confirmed, acceptable corresponding performance) is defined as the Relative Thermal Index (RTI More than one RTI may be appropriate for a given material depending on the property requirements for a given application. In certain cases, higher temperatures are permitted if so specified by the end-use product standard.
RTI Elec — Electrical RTI, associated with critical insulating properties.
RTI Mech Imp — Mechanical Impact RTI, associated with critical impact resistance, toughness, elongation and flexibility properties.
RTI Mech Str — Mechanical Strength (Mechanical without Impact) RTI, associated with critical mechanical strength and structural integrity where impact resistance, resilience and flexibility may not be essential.weixiangbao (2007-10-16 20:29:47)找了几个朋友终于弄明白了,同时感谢alliedsmt!:)
RTI 即相对保证温度,也叫“相对温度指数” 是UL保证材料使用的最高温度。单位为℃。
有时也只标注为TI(保证温度)。
Elec表示对于电气特性的TI ;
imp表示有冲击负荷时的TI;
str表示静态下的TI。alliedsmt (2007-10-16 21:04:28)呵呵,UL的网站上有详细的信息。还可以查询黄卡
http://database.ul.com/cgi-bin/X ... 7222&sequence=1wannianchu (2008-3-14 20:10:38)这是塑料UL认证的黄卡(CCN:QMFZ2),进行的是UL94的燃烧测试;测试很简单,只是说明该产品的燃烧等级(如,HB,V1,V2等);
UL根据你提交的产品成分,来默认的RTI温度值(ELEC、IMP、STR);这个在UL746B中有描述;
ELEC(电气强度):UL746A的21章以及ASTM D149
IMPACT(拉力冲击):根据塑料的热塑和热固分类,有缺口冲击(IZOD)和却贝冲击两种;ASTM D256;
STR(拉伸测试):UL746A和ASTM D638;
只能简单介绍了,这个太难了;
另外补充一点,如果进行RTI温度提升的UL认证的话,要有思想准备;预计12-18个月;约USD30000wannianchu (2008-3-14 20:13:38)QUOTE:
<blockquote style="border: 1px dotted #DDD; margin: 0 1em 1em; padding: 0.5em; line-height: 1.8em;">原帖由 wannianchu 于 2008-3-14 20:10 发表
UL根据你提交的产品成分,来默认的RTI温度值(ELEC、I ... [/quote]再补充一点,样品的制备,目前国内还没有经验,需要到国外专业公司进行;很贵的chenqiuyue (2008-3-15 10:49:14)呵呵,这种产品的UL认证是比较麻烦!
我们公司主要做电器方面的UL认证!
2020-11-23 14:55:20
2020-11-23 14:59:05
2020-11-23 15:01:24
2020-11-23 15:04:51
2020-11-23 15:05:41
2020-11-23 15:12:16
2020-11-23 15:16:55
2020-11-23 15:18:13
2020-11-23 15:19:41
