精益生产 4719 30 2010-2-18 09:25:58
Before designed, KD has already considered adequately the practical needs of the customers, so the finished products appeared more functionality and economical efficiency.<br />
***kd partition wall Excellent structure combination of inner steel and outer aluminium unifies the inside consistency with outside aesthetics perfectly of the partitions for commercial use. <br />
***KD partition panel Slim assembly profiles between modules maximumly bring about the brightness and integrity of the glazed partitions. Covering profiles made of metal increase greatly the stability and flatness of glass panel with large size. <br />
***KD partition wall Finished international patent design of L, T, and Y connections turns the difficulties into highlights of the partition products. <br />
***KD partition wall Perfect sound insulation system of KD partitions completely blocks every channel that transfers sound, which leads to an unusual sound insulation of the partitions. <br />
***KD partitions make every effort to avoid complicated structures in design and enable customers to get perfect product with least cost. <br />
***KD partitions has obtained ETA standard test of impact resistance, which provides guarantee of safe use of the customers. <br />
Doorframes of KD partitions are reinforced by the combination of inside steel support, solid door materials inside and aluminium doorframes outside. <br />
The whole set of partition avoids to be fixed by rivets, which brings about the demountable function.<br />
*** KD partitions involved fixed partition wall and movable partition wall
<!--article end-->
<!--col1 end-->
<script src="http://www.6sq.com/batch.panel.php?rand=706697" type="text/javascript" language="javascript">
<!--user_login end-->
<!--最新帖子-->
<h3>最新发表</h3>
<ul class="global_tx_list3">
<li>victor2008【加分讨论】PMC中物控部门的职责有
2021-3-29 20:46:24
2021-3-29 20:46:51
2021-3-29 20:53:52
2021-3-29 20:54:42
2021-3-29 20:58:32
2021-3-29 20:59:56
2021-3-29 20:59:56
2021-3-29 21:01:48
2021-3-29 21:02:04
