品质英语之二
质量管理 4066 30 2010-2-18 10:29:45
<P>E-L</P>
<P>Effect, 实验效应<BR>Eigenvalue, 特征值<BR>Eigenvector, 特征向量<BR>Ellipse, 椭圆<BR>Empirical distribution, 经验分布<BR>Empirical probability, 经验概率单位<BR>Enumeration data, 计数资料<BR>Equal sun-class number, 相等次级组含量 <BR>Equally likely, 等可能<BR>Equivariance, 同变性<BR>Error, 误差/错误<BR>Error of estimate, 估计误差<BR>Error type I, 第一类错误<BR>Error type II, 第二类错误<BR>Estimand, 被估量<BR>Estimated error mean squares, 估计误差均方<BR>Estimated error sum of squares, 估计误差平方和<BR>Euclidean distance, 欧式距离<BR>Event, 事件<BR>Event, 事件<BR>Exceptional data point, 异常数据点<BR>Expectation plane, 期望平面<BR>Expectation surface, 期望曲面<BR>Expected values, 期望值<BR>Experiment, 实验<BR>Experimental sampling, 试验抽样<BR>Experimental unit, 试验单位<BR>Explanatory variable, 说明变量<BR>Exploratory data analysis, 探索性数据分析<BR>Explore Summarize, 探索-摘要<BR>Exponential curve, 指数曲线<BR>Exponential growth, 指数式增长<BR>EXSMOOTH, 指数平滑方法 <BR>Extended fit, 扩充拟合<BR>Extra parameter, 附加参数<BR>Extrapolation, 外推法<BR>Extreme observation, 末端观测值 <BR>Extremes, 极端值/极值<BR>F distribution, F分布<BR>F test, F检验<BR>Factor, 因素/因子<BR>Factor analysis, 因子分析<BR>Factor Analysis, 因子分析<BR>Factor score, 因子得分<BR>Factorial, 阶乘<BR>Factorial design, 析因试验设计<BR>False negative, 假阴性<BR>False negative error, 假阴性错误<BR>Family of distributions, 分布族<BR>Family of estimators, 估计量族<BR>Fanning, 扇面<BR>Fatality rate, 病死率<BR>Field investigation, 现场调查<BR>Field survey, 现场调查<BR>Finite population, 有限总体<BR>Finite-sample, 有限样本<BR>First derivative, 一阶导数 <BR>First principal component, 第一主成分<BR>First quartile, 第一四分位数<BR>Fisher information, 费雪信息量<BR>Fitted value, 拟合值<BR>Fitting a curve, 曲线拟合<BR>Fixed base, 定基<BR>Fluctuation, 随机起伏<BR>Forecast, 预测<BR>Four fold table, 四格表<BR>Fourth, 四分点<BR>Fraction blow, 左侧比率<BR>Fractional error, 相对误差<BR>Frequency, 频率<BR>Frequency polygon, 频数多边图<BR>Frontier point, 界限点<BR>Function relationship, 泛函关系<BR>Gamma distribution, 伽玛分布<BR>Gauss increment, 高斯增量<BR>Gaussian distribution, 高斯分布/正态分布<BR>Gauss-Newton increment, 高斯-牛顿增量<BR>General census, 全面普查<BR>GENLOG (Generalized liner models), 广义线性模型 <BR>Geometric mean, 几何平均数<BR>Gini's mean difference, 基尼均差<BR>GLM (General liner models), 通用线性模型 <BR>Goodness of fit, 拟和优度/配合度<BR>Gradient of determinant, 行列式的梯度<BR>Graeco-Latin square, 希腊拉丁方<BR>Grand mean, 总均值<BR>Gross errors, 重大错误<BR>Gross-error sensitivity, 大错敏感度<BR>Group averages, 分组平均<BR>Grouped data, 分组资料<BR>Guessed mean, 假定平均数<BR>Half-life, 半衰期<BR>Hampel M-estimators, 汉佩尔M估计量<BR>Happenstance, 偶然事件<BR>Harmonic mean, 调和均数<BR>Hazard function, 风险均数<BR>Hazard rate, 风险率<BR>Heading, 标目 <BR>Heavy-tailed distribution, 重尾分布<BR>Hessian array, 海森立体阵<BR>Heterogeneity, 不同质<BR>Heterogeneity of variance, 方差不齐 <BR>Hierarchical classification, 组内分组<BR>Hierarchical clustering method, 系统聚类法<BR>High-leverage point, 高杠杆率点<BR>HILOGLINEAR, 多维列联表的层次对数线性模型<BR>Hinge, 折叶点<BR>Histogram, 直方图<BR>Historical cohort study, 历史性队列研究 <BR>Holes, 空洞<BR>HOMALS, 多重响应分析<BR>Homogeneity of variance, 方差齐性<BR>Homogeneity test, 齐性检验<BR>Huber M-estimators, 休伯M估计量<BR>Hyperbola, 双曲线<BR>Hypothesis testing, 假设检验<BR>Hypothetical universe, 假设总体<BR>Impossible event, 不可能事件<BR>Independence, 独立性<BR>Independent variable, 自变量<BR>Index, 指标/指数<BR>Indirect standardization, 间接标准化法<BR>Individual, 个体<BR>Inference band, 推断带<BR>Infinite population, 无限总体<BR>Infinitely great, 无穷大<BR>Infinitely small, 无穷小<BR>Influence curve, 影响曲线<BR>Information capacity, 信息容量<BR>Initial condition, 初始条件<BR>Initial estimate, 初始估计值<BR>Initial level, 最初水平<BR>Interaction, 交互作用<BR>Interaction terms, 交互作用项<BR>Intercept, 截距<BR>Interpolation, 内插法<BR>Interquartile range, 四分位距<BR>Interval estimation, 区间估计<BR>Intervals of equal probability, 等概率区间<BR>Intrinsic curvature, 固有曲率<BR>Invariance, 不变性<BR>Inverse matrix, 逆矩阵<BR>Inverse probability, 逆概率<BR>Inverse sine transformation, 反正弦变换<BR>Iteration, 迭代 <BR>Jacobian determinant, 雅可比行列式<BR>Joint distribution function, 分布函数<BR>Joint probability, 联合概率<BR>Joint probability distribution, 联合概率分布<BR>K means method, 逐步聚类法<BR>Kaplan-Meier, 评估事件的时间长度 <BR>Kaplan-Merier chart, Kaplan-Merier图<BR>Kendall's rank correlation, Kendall等级相关<BR>Kinetic, 动力学<BR>Kolmogorov-Smirnove test, 柯尔莫哥洛夫-斯米尔诺夫检验<BR>Kruskal and Wallis test, Kruskal及Wallis检验/多样本的秩和检验/H检验<BR>Kurtosis, 峰度<BR>Lack of fit, 失拟<BR>Ladder of powers, 幂阶梯<BR>Lag, 滞后<BR>Large sample, 大样本<BR>Large sample test, 大样本检验<BR>Latin square, 拉丁方<BR>Latin square design, 拉丁方设计<BR>Leakage, 泄漏<BR>Least favorable configuration, 最不利构形<BR>Least favorable distribution, 最不利分布<BR>Least significant difference, 最小显著差法<BR>Least square method, 最小二乘法<BR>Least-absolute-residuals estimates, 最小绝对残差估计<BR>Least-absolute-residuals fit, 最小绝对残差拟合<BR>Least-absolute-residuals line, 最小绝对残差线<BR>Legend, 图例<BR>L-estimator, L估计量<BR>L-estimator of location, 位置L估计量<BR>L-estimator of scale, 尺度L估计量<BR>Level, 水平<BR>Life expectance, 预期期望寿命<BR>Life table, 寿命表<BR>Life table method, 生命表法<BR>Light-tailed distribution, 轻尾分布<BR>Likelihood function, 似然函数<BR>Likelihood ratio, 似然比<BR>line graph, 线图<BR>Linear correlation, 直线相关<BR>Linear equation, 线性方程<BR>Linear programming, 线性规划<BR>Linear regression, 直线回归<BR>Linear Regression, 线性回归<BR>Linear trend, 线性趋势<BR>Loading, 载荷 <BR>Location and scale equivariance, 位置尺度同变性<BR>Location equivariance, 位置同变性<BR>Location invariance, 位置不变性<BR>Location scale family, 位置尺度族<BR>Log rank test, 时序检验 <BR>Logarithmic curve, 对数曲线<BR>Logarithmic normal distribution, 对数正态分布<BR>Logarithmic scale, 对数尺度<BR>Logarithmic transformation, 对数变换<BR>Logic check, 逻辑检查<BR>Logistic distribution, 逻辑斯特分布<BR>Logit transformation, Logit转换<BR>LOGLINEAR, 多维列联表通用模型 <BR>Lognormal distribution, 对数正态分布<BR>Lost function, 损失函数<BR>Low correlation, 低度相关<BR>Lower limit, 下限<BR>Lowest-attained variance, 最小可达方差<BR>LSD, 最小显著差法的简称<BR>Lurking variable, 潜在变量 <BR></P></div>
</div>
2021-3-14 16:31:35
2021-3-14 16:31:50
2021-3-14 16:32:06
2021-3-14 16:32:19
2021-3-14 16:48:22
2021-3-14 16:55:11
2021-3-14 17:01:11
2021-3-14 17:01:38
