工业工程GSD代码
文档共享 3659 30 2010-3-1 08:11:18
工业工程的一个小资料,关于代码方面的国际通用标准资料。很多公司都将这个源代码修改后,变成自己公司的新代码。
GENERAL SEWINGDATA
LICNSED DATA CARD
 Category ElementCode TMU Motion
   要素  时间 Sequences
 分类 中文英文代码 单元 动作要素
 Obtain and 同时取两块裁片及配对Match & get 2 parts togetherMG2T 76 G.G.P.G.G
 match part 先后取两块裁片及配对Match & get 2 parts separatelyMG2S 107 G.P.G.P.G.G
 orparts 将裁片移至压脚位Match parts to FOOT(without obtain)
FOOT 38 P.F
 拿取并 单手取附件配对(轻易动作)Match & add part with 1 hand (easy) MAPE 50 G.P.G
 比对裁片 单手取附件配对Match & add part with 1 hand
MAP1 56 G.P.G
   双手取附件配对Match & add part with 2 hand
MAP2 69 G.P.G.P.G
 Aligning 将两块裁片对准或调整位置Align and match 2 partsAM2P 61 G.G.P.G
 and 将单块裁片对准或调整位置Align 1 part(top)
AJPT 43 G.P.G
 adjusting 将缝合件(调整位置)重新对准及移正压脚位Align & reposition assembly under foot ARPN 75 G.P.G.P.F
 对齐与调节 将裁片调整位置及转角,抚平或推移Align or adjust part(s) by pushing or sliding
APSH 24 G.P
 Forming 折叠Form fold
FFLD 43 G.P.G
 shapes 在已折叠裁片上压上折痕Form crease in folded part
FCRS 28 G.GW.P.PW
 成形 将已折叠裁片打开Form unfold or layout
FUNF 23 G.P
 Trimming 剪线:剪刀剪(第一次)Trim-cut with scissors(lst) TCUT 50 G.P.P.P
 and tool use 剪线:再用剪刀剪Trim-cut with scissors(additional)TCAT 25 P.P
 剪及工具 剪线:用固定剪刀剪Trim-cut thread with fixed bladeTBLD 33 G.P
 运用 剪线:用剪刀剪断连串裁片Trim-deCHain parts with scissorsTDCH 49 G.P.P.P
 Asiding 摆放:推移(滑动)Aside-push away (sliding)APSH 24 G.P
 放到一边 摆放:用单手Aside-part with 1 hand
AS1H 23 G.P
   摆放:用双手Aside-part with 2 hand
AS2H 42 G.G.P
   车缝近似大于1CMMachine sew 1cm approx greater than 1cmMSIA 17 F.F
   刚好1CMMachine sew 1cm accurately within1cm MSIB 26 F.PB.F
 Handling 刚好车1/2CM长Machine sew 1cm precisely within1/2cm MSIC 37 F.PC.F
 machine 转动手轮升降缝针Machine Hand wheel to raise/lower meedle
MHDW 46 G.P.G.P.G
 控制机器 用手起针回针Machine back Tack at beginning(lever)
MBTB 34 G.P.P.P.G
   用手落针回针Machine back Tack at End(lever)
MBTE 37 G.P.PT.P.P.G
   单手取裁片(轻易动作)Get part with 1
hand(Easy)
GP1E 14 G
   单手取裁片Get part with 1
hand
GP1H 20 G
   双手取裁片Get part with 2
hand
GP2H 33 G.G
 Get and put 仅仅是用手接触一下裁片Get part contact only
GPCO 9 G
 data 从另一只手拿取裁片Get part
from other
hannd
GPOH 6 G
 拿和放 调整抓的动作Ger part by adjusting grasp
GPAG 10 G
   把裁片放在近似的位置上Put part to approximate location
PPAL 10 P
   把裁片送到另一只 手上Put part to other
hand
PPOH 6 P
   把裁片放到期裁片堆上Put part onto stack
PPST 14 P
   把裁片一次性放好Put part locate oncePPL1 27 P
   裁片二次才能放好Put part locate twice
PPL2 47 P.P
   脚或腿的短距离动作Foot or short
leg motion
F 9
   走路或移动身体Pace or step to move bodyP 18
 Additional 弯腰起身Bend(and arise)
B 61
 MTM 弯下去Bend down
BD 29
 elements 起身Arise from bending
AB 32
 增加额外的 坐下去Sit
SIT 35
 TMU 站起来Stand
STD 44
 元素 眼球动作(简单的两边对比)Eye
action(** binary checks)
E 7
   旋转Crank
C
 15
   重握Regrasp
R 6
   施加压力Apply pressureA
 14
   写一个单词Write a word
WW 85
 Clerical data 写一个字母Write aletter
WL 25
 记录数据 写一个数字Write a digit or
number
WD 17
   写一个标点符号Write a punctuation mark
WP 10
   读一个单词Read word
RW 5
2021-3-13 20:34:51
2021-3-13 20:35:10
2021-3-13 20:37:59
2021-3-13 20:38:58
2021-3-13 20:40:32
2021-3-13 20:40:57
2021-3-13 20:51:29
2021-3-13 20:52:33
19015
